It would be highly recommended to upgrade the CMS to 1.7.9 and Xibo for Android to 1.7R64.
Other than that, could you please try using the following example stream in local video in Xibo to see if that will work for you - rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
If that works, then it could imply an issue with your local stream configuration, so we will focus on that then.
thank you for response,
the LINK that you give us, it’s working fine and can play at Xibo Android Player
So, as you said that we can focusing on our local stream configuration to solve this issue,
so what exactly that stream configuration we must to set to fullfill the xibo RSTP need ?
