We're very excited to be releasing today a "Technology Preview" of our forthcoming Player for Linux.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/linux-player-technology-preview-0-2a/
SO excited for thisā¦! Thank you for making it happen so quckly.
Run perfectly!
We are very happy and the result of this preview was very gratifying.
ā./Player: error while loading shared libraries: libgeoclue.so.0: cannot open shared object file: No such file or directoryā on Ubuntu 17.10 (Artful Aardvark) 64-bit. gstreamer1.0-libav installed at latest version (1.12.2-1).
Weāve not provided or built binaries for Ubuntu 17.10. For now weāre just after feedback on Ubuntu 16.04 64 bit please.
Just tried the player on a Minix x7. Canāt wait for this! I just need to figure out how to use a screensaver the same way we did on the Windows player. Perfect touch screen setup!
Works well for me too. Iāve only tested so far in a VM though. Iāll try some of my layouts when time allows
We are so exited to hear about this.
I just tested it on ubuntu 16.04, a fresh install. The following errors occured:
Did you give the full path to the samples directory? The errors you mention imply perhaps you didnāt.
Thanks for your reply, I did not. I will do another testrun in the next few days.
Loving Xibo! Thanks for all of your hard work team! When I get some money I will absolutely donate to the cause.
Linux Player running smoothly on my 16.04LTS 64bit - i3-3110M Quad 2.4GHz 4GB Laptop.
Iām getting very excited about the progress!
Any idea of a rollout date yet or is it still too early?
Best Regards,
ReadySign
Thanks for your feedback. When we have any more information about development weāll make another announcement.
Hi Alex,
Everything fine with sample Layouts but After copying windows player content to sample directory to check with my layout iām getting below error while running player:
./Player --example-dir=/home/amit/Downloads/1st/XiboLinux-0.2a/samples/inpdigitalclient1.7.10/
[13:43:36] [info]: Example directory is /home/amit/Downloads/1st/XiboLinux-0.2a/samples/inpdigitalclient1.7.10/
[13:43:36] [debug]: parse layout
[13:43:36] [debug]: parse region
terminate called after throwing an instance of āboost::exception_detail::clone_impl<boost::exception_detail::error_info_injectorboost::property_tree::ptree_bad_path >ā
what(): No such node (options)
Aborted (core dumped)
Regards,
Amit
Was the layout taken from a 1.7 or 1.8 series Player please? Your path suggests it might be from 1.7, in which case it wouldāt be supported.
Hi XIbo friends,
Any thoughts on ETA for the Linux Player? Microsoft has made the lives of digital signage operators completely miserable with Windows 10. Weāre really excited to start using Ubuntu with Xiboā¦!
Cheers
We donāt have a date to announce. Weāll have another preview coming soon though.
The next Development Preview is now available:
Hello
Is it possible to use counter with this linux player like we used to?
I stil have a server with old specs with counter running.
Thanks!
I guess not as this player canāt connect to the old CMS verison that supported the Counterā¦ Thanks anyway
