I’m using Xibo on Lubuntu. I am having 1-3 lock ups per day. When viewing the most recent lockup it looks like it happened right after I lost wifi and reconnected. log:
Jul 01 11:06:23 beta kernel: wls33: deauthenticated from 48:f8:b3:be:36:4a (Reason: 16=GROUP_KEY_HANDSHAKE_TIMEOUT)
Jul 01 11:06:24 beta kernel: wls33: authenticate with 48:f8:b3:be:36:4a
Jul 01 11:06:24 beta kernel: wls33: send auth to 48:f8:b3:be:36:4a (try 1/3)
Jul 01 11:06:25 beta kernel: wls33: authenticated
Jul 01 11:06:25 beta kernel: wls33: associate with 48:f8:b3:be:36:4a (try 1/3)
Jul 01 11:06:25 beta kernel: wls33: RX AssocResp from 48:f8:b3:be:36:4a (capab=0x1411 status=0 aid=2)
Jul 01 11:06:25 beta kernel: wls33: associated
Jul 01 11:06:25 beta snapd[632]: SIGABRT: abort
Jul 01 11:06:25 beta snapd[632]: PC=0x56232d41f273 m=2 sigcode=0
Jul 01 11:06:25 beta snapd[632]: goroutine 0 [idle]:
Jul 01 11:06:25 beta snapd[632]: runtime.usleep(0x80e00002710, 0xd00000000, 0x80b83477d06, 0x45d964b800, 0x27103e357e20, 0x80e22117f69, 0x45d964b800, 0x36, 0x0, 0x80b83477d06, …)
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/runtime/sys_linux_amd64.s:144 +0x53
Jul 01 11:06:25 beta snapd[632]: runtime.sysmon()
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/runtime/proc.go:4221 +0xd5
Jul 01 11:06:25 beta snapd[632]: runtime.mstart1(0xc400000000)
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/runtime/proc.go:1227 +0xeb
Jul 01 11:06:25 beta snapd[632]: runtime.mstart()
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/runtime/proc.go:1193 +0x78
Jul 01 11:06:25 beta snapd[632]: goroutine 1 [select, 147 minutes]:
Jul 01 11:06:25 beta snapd[632]: main.run(0xc4202429c0, 0x0, 0x0)
Jul 01 11:06:25 beta snapd[632]: /build/snapd-ghjK3c/snapd-2.39.3/_build/src/github.com/snapcore/snapd/cmd/snapd/main.go:145 +0x4e2
Jul 01 11:06:25 beta snapd[632]: main.main()
Jul 01 11:06:25 beta snapd[632]: /build/snapd-ghjK3c/snapd-2.39.3/_build/src/github.com/snapcore/snapd/cmd/snapd/main.go:58 +0xd7
Jul 01 11:06:25 beta snapd[632]: goroutine 20 [syscall, 147 minutes]:
Jul 01 11:06:25 beta snapd[632]: os/signal.signal_recv(0x0)
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/runtime/sigqueue.go:139 +0xa8
Jul 01 11:06:25 beta snapd[632]: os/signal.loop()
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/os/signal/signal_unix.go:22 +0x24
Jul 01 11:06:25 beta snapd[632]: created by os/signal.init.0
Jul 01 11:06:25 beta snapd[632]: /usr/lib/go-1.10/src/os/signal/signal_unix.go:28 +0x43
Jul 01 11:06:25 beta snapd[632]: goroutine 22 [select, 147 minutes, locked to thread]:
Jul 01 11:06:25 beta snapd[632]: runtime.gopark(0x56232dff0000, 0x0, 0x56232da49c49, 0x6, 0x18, 0x1)
