Hi, what should I write in the Dataset column’s field “List Content” when the Data type is “Library Image” to get the pre-selected images to the combo box? Thanks for help.
Thank you for your message and welcome to the Community!
The List Content field in your Column settings is for use with String or Number Value Columns. It will not work with Library Images as the format is not compatible. To demonstrate, you can see in my screenshot below I have created a couple of String value Columns and added some CSVs into the List Content fields:
If I now go to the Row View of my dataset, I can choose those values I added to the List Content column:
Thanks. I could see what it did with strings but was strugglung with images. Will need to find some other way for my editors to use a selection of images.
