Library/certs/encryption.key missing
Installation Method
Custom IIS
Operating System
Windows 2019
I can’t access my media or playlists since upgrading to 4.0
Turning on Test mode generates the message
PHP Warning: file_get_contents(D:\WebSites\SHRXibo\libaray\certs/encryption.key): Failed to open stream: No such file or directory in D:\WebSites\SHRXibo\xibo\xibo-cms-4.0.0\lib\Service\ConfigService.php on line 600
When I go to either Media or Layouts pages, but I can’t find a folder certs in the library folder.
You will need to make sure a public/private and encryption key are provided in your library folder as per the instructions here:
We will update the documentation to make sure this is clearer!
That’s how you can easily do that on Windows Server/ Custom Installation:
Thank you this fixed it.
