LG WebOS using Xibo application
Hello Xibo Admin,
Good day!
I’ve been using Xibo for 3 years now. Currently, our device is an ordinary TV monitor and a PC. I would like to upgrade the system with an LG WebOS. Since I haven’t seen the LG TV. I just wanted to know if the TV has a default setting in which automatically turns to the WebOs once the unit is on?
Thanks!
Welcome to the Xibo Community Wiled_Lacsamana!
If Xibo was ON before you turned off the TV, when you turn in back ON it will start Xibo automatically.
You can also lock out the buttons on the screen itself from the Display Settings Profile so people cant change input.
Thank you Nell for the information.
