I am having issue with Layouts not playing. I have had many layouts playing successfully until recently. Now, when I make a change to an existing layout and save it, it no longer plays, even though scheduled. But, I can make a copy of the layout, save as a new name and new layout will play.
This is happening on existing layouts, but I also tried it on a brand new layout. I created a simple layout with a single region to display a single webpage. If changed, the revised layout no longer plays. The display will instead start to play the default layout instead. If I copy the revised layout to a new layout, it will play fine when scheduled.
Tried a layout with an image, rather than a webpage, same issue.
Running version 1.8.3 in Docker on Windows 2012 R2. Clients are Windows 10. Have been using Xibo for quite some time, but this issue is something I can’t figure out. Thoughts?
