Layout - Region webpage
Hi!
I’am running Xibo CMS version 1.8.1, a new clean install.
When I try to add a region with a webpage and enter a link, for example http://google.com I get a message like this:
“Please enter a link”
This was working on my prev. install with 1.7.9
Is there a fix for this?
Kind regards
Alex
http://google.com works on the 1.8.1 installs I have access to.
Is it a Docker-based install? Or something custom? If custom, do you have web in the URL you use to access the CMS?
I run a cloud verion, but when I create a layout with http://www.google.com its not displaying. I get black screen nothing else, all the other layouts runs well but thisone is just black screen.
What might be wrong, I have android7.1 player.
thak you for advices
