Layout not displaying like it should
Good day,
I have an issue with my layout on my Xibo(android device) when it comes to displaying the layout,it only shows the main picture but not the complete layout it also skips some of the slides.
When it comes to VIdeo it displays perfectly.
Could you please assist as i dont know what else to troubleshoot.
Kind regards,
Jeffrey
It would be good to know what CMS and Xibo for Android versions are you using?
As for the layout itself, if possible please export it from your CMS, upload to WeTransfer/dropbox or similiar service of your choice and share the download link with me via private message.
I’ll then import your layout to my dev CMS and have a look at it.
If there are more than one layout, it would be good to know how did you schedule them to your display.
Hi Peter,
Apologies on the late response, the xibo started working perfectly.
So no need for anymore troubleshooting.
Kind regards,
Jeffrey
payd
Jeffrey Nemusombori
IT Administrator
t.+27 21 910 7700
www.payd.cojeffrey.nemusombori@payd.co
I’m glad to hear that, perhaps it was just a case of player downloading missing files then.
