Layout freezing and crashing when trying to check logs
Xibo Version: v4 R06
Since updating to this version I have been facing the same issue on different displays. The displays use a layout with a background showing the current date and time on top, and a playlist of different images reproducing in the middle. Since the update, these displays will eventually freeze in one specific image and completely remove the background, and when I try to check the logs the player immediately crashes, so I have no way of checking them.
replace that image and test, if jpg reformat it to png or vice versa …
Hi, so I tried out replacing the image and even after testing different layouts the same issue is happening. Right now I was trying another layout which displays a news live stream and the stream, and different layouts elements (the hour and a news report at the bottom) froze, again when trying to access the logs the player crashed.
