Relatively new to Xibo and trying to get a grasp of troubleshooting.Took a look at
Saw some error messages, but resolved them.
We have the layout that will not play, so i looked into the layout and found media that no longer existed in the library.
I trimmed the media from the layout that wasn’t there anymore. Now the Android client is showing something like this:
54 - Original Layout
40 - *Default Layout
Schedule Status
All layouts(=not scheduled):54, 40(Default)
Next: 2018-12-31 00:00:00
Scheduled Layouts: 40,
Valid Layouts: 40,
Invalid Layouts:
Blacklist:
Last 5 log messages:
but when i copy the layout and have it scheduled everything loads and plays out perfectly
71 - Copied Layout
Schedule Status
All layouts(=not scheduled):71, 40(Default)
Next: 2018-01-01 00:00:00
Scheduled Layouts: 71,
Valid Layouts: 71,
Invalid Layouts:
Any suggestions or input on what to look for? I’m trying to figure out how and why the original layout is “corrupted”, so i can prevent the user from causing the issue in the first place.
I have exported the layout.
Will not allow the .zip files to be uploaded here.
Is this something i can email to you?
I am using Android Player, the layout has 1 region inside of it, the full region size 1920x1080
I don’t see the Always options, does this have to do with scheduling?
Under Status in the Xibo client app, there is no Error warning on either display or message that says they are invalid.
In the CMS dashboard, both layouts can be previewed and run.
If by Cloud hosting, you mean Spring Signage cloud hosting, then do please create a support ticket / send us an email about it - preferably from the same email address as in our Customer Portal, mention the Instance name, layout id and all the details and we will take a look for you.
