Environment Checks
<table class="table">
<thead>
<tr>
<th class="group-false">Item</th>
<th class="group-false" data-sorter="tickcross">Status</th>
<th class="group-false">Advice</th>
</tr>
</thead>
<tbody>
<tr >
<td>PHP Version</td>
<td><span class="glyphicon glyphicon-ok"></span></td>
<td>PHP version 5.3.3 or later required. Detected 5.3.3</td>
</tr>
<tr >
<td>File System Permissions</td>
<td>Write access required for settings.php and install.php</td>
</tr>
<tr >
<td>MySQL database (PHP MySql)</td>
<td>MySQL support must be enabled in PHP.</td>
</tr>
<tr >
<td>MySQL database (PDO MySql)</td>
<td>PDO support with MySQL drivers must be enabled in PHP.</td>
</tr>
<tr >
<td>JSON Extension</td>
<td>PHP JSON extension required to function.</td>
</tr>
<tr >
<td>SOAP Extension</td>
<td>PHP SOAP extension required to function.</td>
</tr>
<tr >
<td>GD Extension</td>
<td>PHP GD extension to function.</td>
</tr>
<tr >
<td>Session</td>
<td>PHP session support to function.</td>
</tr>
<tr >
<td>FileInfo</td>
<td>Requires PHP FileInfo support to function. If you are on Windows you need to enable the php_fileinfo.dll in your php.ini file.</td>
</tr>
<tr >
<td>PCRE</td>
<td>PHP PCRE support to function.</td>
</tr>
<tr >
<td>Gettext</td>
<td>PHP Gettext support to function.</td>
</tr>
<tr >
<td>Calendar Extension</td>
<td>PHP Calendar extension to function.</td>
</tr>
<tr >
<td>DOM Extension</td>
<td>PHP DOM core functionality enabled.</td>
</tr>
<tr >
<td>DOM XML Extension</td>
<td>PHP DOM XML extension to function.</td>
</tr>
<tr >
<td>Mcrypt Extension</td>
<td>PHP Mcrypt extension to function.</td>
</tr>
<tr >
<td>Allow PHP to open external URLs</td>
<td>You must have allow_url_fopen = On in your PHP.ini file for RSS Feeds / Anonymous statistics gathering to function.</td>
</tr>
<tr >
<td>DateTimeZone</td>
<td>This enables us to get a list of time zones supported by the hosting server.</td>
</tr>
<tr >
<td>ZIP</td>
<td>This enables import / export of layouts.</td>
</tr>
<tr >
<td>Large File Uploads</td>
<td>Support for uploading large files is recommended.</td>
</tr>
<tr >
<td>Internationalization</td>
<td>International Support for formatting Dates, Numbers, etc.</td>
</tr>
<tr >
<td>cURL</td>
<td>cURL is used to fetch data from the Internet or Local Network</td>
</tr>
</tbody>
</table>
LOG Dump
Date,Page,Function,Message
"2018-02-27 08:10:30","User","DisplayList","SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY displayid. Params: array (
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): CData section not finished
<h1 style="color: rgb(31, 19, 217);"><span style=" in Entity, line: 36</errormsg>
<errornum>2</errornum>
<errortype>Warning</errortype>
<scriptname>/var/www/html/xibo/lib/data/layout.data.class.php</scriptname>
<scriptlinenum>1744</scriptlinenum>
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag text line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag raw line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag media line 20 in Entity, line: 36</errormsg>
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag region line 3 in Entity, line: 36</errormsg>
"2018-02-27 08:10:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag layout line 2 in Entity, line: 36</errormsg>
"2018-02-27 08:09:59","User","DisplayList","SQL: SELECT display.displayid, display.display, displaygroup.description, layout.layout, display.loggedin, IFNULL(display.lastaccessed, 0) AS lastaccessed, display.inc_schedule, display.licensed, display.email_alert, displaygroup.DisplayGroupID, display.ClientAddress, display.MediaInventoryStatus, display.MacAddress, display.client_type, display.client_version, display.client_code, display.screenShotRequested, display.storageAvailableSpace, display.storageTotalSpace, currentLayout.layout AS currentLayout, currentLayout.layoutId AS currentLayoutId FROM display INNER JOIN lkdisplaydg ON lkdisplaydg.DisplayID = display.DisplayID INNER JOIN displaygroup ON displaygroup.DisplayGroupID = lkdisplaydg.DisplayGroupID LEFT OUTER JOIN layout ON layout.layoutid = display.defaultlayoutid LEFT OUTER JOIN layout currentLayout ON currentLayout.layoutId = display.currentLayoutId WHERE displaygroup.IsDisplaySpecific = 1 ORDER BY displayid. Params: array (
"2018-02-27 08:09:54","layout","","Loading permissions for layoutid 9"
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): CData section not finished
<scriptname>/var/www/html/xibo/lib/pages/layout.class.php</scriptname>
<scriptlinenum>982</scriptlinenum>
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag text line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag raw line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag media line 20 in Entity, line: 36</errormsg>
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag region line 3 in Entity, line: 36</errormsg>
"2018-02-27 08:09:54","layout","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag layout line 2 in Entity, line: 36</errormsg>
"2018-02-27 08:09:47","Userdata","entries","SQL:
SELECT `user`.userId, userName, userTypeId, loggedIn, email, homePage, lastAccessed, newUserWizard, retired, `userGroups`.groupId, `userGroups`.libraryQuota
FROM `user`
LEFT OUTER JOIN (
SELECT `group`.groupId, `group`.libraryQuota, `lkusergroup`.userId
FROM `lkusergroup`
INNER JOIN `group`
ON `group`.groupId = `lkusergroup`.groupId
AND `group`.isUserSpecific = 1
) userGroups
ON userGroups.userId = `user`.userId
WHERE 1 = 1
AND user.retired = :retired ORDER BY username. Params: array (
'retired' => 0,
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): CData section not finished
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag text line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag raw line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag media line 20 in Entity, line: 36</errormsg>
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag region line 3 in Entity, line: 36</errormsg>
"2018-02-27 08:06:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag layout line 2 in Entity, line: 36</errormsg>
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): CData section not finished
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag text line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag raw line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag media line 20 in Entity, line: 36</errormsg>
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag region line 3 in Entity, line: 36</errormsg>
"2018-02-27 08:05:12","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag layout line 2 in Entity, line: 36</errormsg>
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): CData section not finished
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag text line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag raw line 22 in Entity, line: 36</errormsg>
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag media line 20 in Entity, line: 36</errormsg>
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag region line 3 in Entity, line: 36</errormsg>
"2018-02-27 08:01:46","","","<errormsg>DOMDocument::loadXML(): Premature end of data in tag layout line 2 in Entity, line: 36</errormsg>
Display Dump
DisplayID: 14
Display: NC-Blauwehal
Default Layout: Rest PBF New
Logged In: 0
Last Accessed: 1475159490
Interleave: 0
Licensed: 1
DisplayID: 22
Display: PC-KANTINE
Logged In: 1
Last Accessed: 1519715418
Interleave: 0
Licensed: 1
DisplayID: 24
Display: NC-RECEPTIE
Default Layout: Receptie
Logged In: 1
Last Accessed: 1519715426
Interleave: 0
Licensed: 1
DisplayID: 26
Display: PC-PRODUCTION
Logged In: 1
Last Accessed: 1519715187
Interleave: 0
Licensed: 1
DisplayID: 28
Display: NC--CLUJ
Default Layout:
Logged In: 0
Last Accessed: 1508318385
Interleave: 0
Licensed: 1
DisplayID: 29
Display: PC-XIBOCJ
Default Layout:
Logged In: 0
Last Accessed: 1508830592
Interleave: 0
Licensed: 1
DisplayID: 30
Display: PC-RKARSENBARG
Default Layout:
Logged In: 0
Last Accessed: 1516893292
Interleave: 0
Licensed: 1
DisplayID: 31
Default Layout:
Logged In: 0
Last Accessed: 1517920347
Interleave: 0
Licensed: 0
Settings Dump
Setting: MEDIA_DEFAULT - Value: public
Setting: LAYOUT_DEFAULT - Value: public
Setting: defaultUsertype - Value: User
Setting: userModule - Value: module_user_general.php
Setting: defaultTimezone - Value: Europe/Amsterdam
Setting: mail_to - Value: ict@pbfgroup.nl
Setting: mail_from - Value: xibo@pbfgroup.nl
Setting: jpg_length - Value: 10
Setting: ppt_length - Value: 10
Setting: swf_length - Value: 10
Setting: audit - Value: audit
Setting: LIBRARY_LOCATION - Value: data/xibo/
Setting: HELP_BASE - Value: http://www.xibo.org.uk/manual/en/
Setting: PHONE_HOME - Value: Off
Setting: PHONE_HOME_URL - Value: http://www.xibo.org.uk/stats/track.php
Setting: PHONE_HOME_DATE - Value: 0
Setting: SERVER_MODE - Value: Production
Setting: MAINTENANCE_ENABLED - Value: Off
Setting: MAINTENANCE_EMAIL_ALERTS - Value: On
Setting: MAINTENANCE_KEY - Value: changeme
Setting: MAINTENANCE_LOG_MAXAGE - Value: 0
Setting: MAINTENANCE_STAT_MAXAGE - Value: 30
Setting: MAINTENANCE_ALERT_TOUT - Value: 12
Setting: SHOW_DISPLAY_AS_VNCLINK - Value:
Setting: SHOW_DISPLAY_AS_VNC_TGT - Value: _top
Setting: MAINTENANCE_ALWAYS_ALERT - Value: Off
Setting: SCHEDULE_LOOKAHEAD - Value: On
Setting: REQUIRED_FILES_LOOKAHEAD - Value: 172800
Setting: REGION_OPTIONS_COLOURING - Value: Media Colouring
Setting: LAYOUT_COPY_MEDIA_CHECKB - Value: Unchecked
Setting: MAX_LICENSED_DISPLAYS - Value: 0
Setting: LIBRARY_MEDIA_UPDATEINALL_CHECKB - Value: Unchecked
Setting: USER_PASSWORD_POLICY - Value:
Setting: USER_PASSWORD_ERROR - Value:
Setting: MODULE_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: LIBRARY_SIZE_LIMIT_KB - Value: 0
Setting: MONTHLY_XMDS_TRANSFER_LIMIT_KB - Value: 0
Setting: DEFAULT_LANGUAGE - Value: en_GB
Setting: TRANSITION_CONFIG_LOCKED_CHECKB - Value: Unchecked
Setting: GLOBAL_THEME_NAME - Value: default
Setting: DEFAULT_LAT - Value: 51.504
Setting: DEFAULT_LONG - Value: -0.104
Setting: SCHEDULE_WITH_VIEW_PERMISSION - Value: No
Setting: SETTING_IMPORT_ENABLED - Value: 1
Setting: SETTING_LIBRARY_TIDY_ENABLED - Value: 1
Setting: SENDFILE_MODE - Value: Off
Setting: EMBEDDED_STATUS_WIDGET - Value:
Setting: PROXY_HOST - Value:
Setting: PROXY_PORT - Value: 0
Setting: PROXY_AUTH - Value:
Setting: DATE_FORMAT - Value: Y-m-d H:i
Setting: DETECT_LANGUAGE - Value: 0
Setting: DEFAULTS_IMPORTED - Value: 1
Setting: FORCE_HTTPS - Value: 0
Setting: ISSUE_STS - Value: 0
Setting: STS_TTL - Value: 600
Setting: MAINTENANCE_ALERTS_FOR_VIEW_USERS - Value: 0
Setting: CALENDAR_TYPE - Value: Gregorian
Setting: DASHBOARD_LATEST_NEWS_ENABLED - Value: 1
Setting: LIBRARY_MEDIA_DELETEOLDVER_CHECKB - Value: Unchecked
Setting: USE_INTL_DATEFORMAT - Value: 0
Setting: PROXY_EXCEPTIONS - Value:
Setting: CDN_URL - Value:
Sessions Dump
UserAgent: Mozilla/5.0 (Windows NT 10.0; WOW64; rv:52.0) Gecko/20100101 Firefox/52.0
RemoteAddress: 192.168.27.85
Session Data
pagename|s:5:"fault";token|s:32:"c3ad847c75e33196b4bf8d1b3aa54e15";token_timeout|i:1519715430;message|s:0:"";usertype|s:1:"1";layout|a:9:{s:13:"filter_layout";s:0:"";s:13:"filter_userid";i:0;s:14:"filter_retired";i:0;s:20:"filterLayoutStatusId";s:1:"1";s:17:"showDescriptionId";s:1:"2";s:8:"showTags";i:0;s:13:"showThumbnail";i:1;s:11:"filter_tags";s:0:"";s:12:"LayoutFilter";i:0;}gridToken|s:32:"6603e62066c2faab3e912d60d1ec4200";gridToken_timeout|i:1519715388;timeLineView|s:4:"list";content|a:10:{s:4:"type";s:4:"text";s:11:"filter_type";s:0:"";s:11:"filter_name";s:0:"";s:8:"filterId";i:0;s:12:"filter_owner";i:0;s:14:"filter_retired";i:0;s:26:"filter_duration_in_seconds";i:0;s:20:"filter_showThumbnail";i:0;s:8:"showTags";i:0;s:6:"Filter";i:0;}display|a:7:{s:14:"filter_display";s:0:"";s:16:"filterMacAddress";s:0:"";s:19:"filter_displaygroup";i:0;s:15:"filter_showView";i:0;s:13:"filterVersion";s:0:"";s:18:"filter_autoRefresh";i:0;s:13:"DisplayFilter";i:0;}log|a:8:{s:6:"Filter";i:0;s:11:"filter_type";i:0;s:15:"filter_function";s:0:"";s:11:"filter_page";s:0:"";s:13:"filter_fromdt";s:0:"";s:14:"filter_display";i:0;s:14:"filter_seconds";s:3:"120";s:21:"filter_intervalTypeId";s:1:"1";}auditlog|a:5:{s:6:"Filter";i:0;s:12:"filterFromDt";s:0:"";s:10:"filterToDt";s:0:"";s:10:"filterUser";s:0:"";s:12:"filterEntity";s:0:"";}assign_token|s:32:"661182344cb436ffd77109adfbe644c5";assign_token_timeout|i:1519641976;username|s:10:"xibo_admin";user_admin|a:4:{s:15:"filter_username";s:0:"";s:17:"filter_usertypeid";i:0;s:13:"filterRetired";i:0;s:6:"Filter";i:0;}ErrorMessage|s:47:"You do not have permissions to edit this layout";userid|s:1:"1";
