Layout Background on all regions?
Hi
(XIBO 1.7.10)
I encounter the following problem:
When creating a new layout, i define a background picture. (JPG)
then i define 4 regions
But when i look at the regions on the player (W10) i see the layout background picture on all 4 regions
Am i doing something wrong?
Regions are transparent, so you would expect to see the background where your regions if the content doesn’t fill the region.
If you mean that the layout background is misaligned where your regions are, then likely you have your Windows 10 Display Scaling setting set to something other than 100%. You need to change that in your Windows Display properties to 100%.
