hola. Tengo un problema, descargue la aplicación xibo en la pantalla y mi pc detecto el cms pero cuando quiero programar el layout no me deja verlo en el tv
Peter
April 25, 2016, 3:17pm
2
It seems that your default layout (id 18 in CMS) is invalid therefore your device is having problems with it.
If you can’t find out why is it invalid, please export your layout and send it to me via pm.
Problem:
Layout will not play / the splash screen is shown instead of playing the Layout.
Cause:
Xibo requires all Layouts to contain something to show. For a Layout to be valid to play on a Xibo Player, it must meet the following criteria:
Must have at least one Region on the Layout
All Regions on the Layout must have at least one valid Media item on it
If the Layout doesn’t meet that specification, then the Player won’t attempt to run the Layout and so the Layout will be missing from you…
