Issue in Installing Xibo-cms-1.8.3 on Red Hat Server
I am trying to install cms v1.8.3 on a redhat server RHEL 7.5. It is a manual installation where I can see the installation page checking the prerequisites but after that when I go to next page I am getting a error “page not found” at the path …/web/install/2 and thus not able to install. In the prerequisites php mcrypt is missing. I have tried to fix mcrypt but not supporting for red hat. How can I resolve this issue? Do I need to do some configuration for installing it on red hat server?
Any help regarding this would be appreciated.
Thanks.
Please check the manual page on setting up the correct environment for Xibo. You should not have “web” in the URL you’re using to access the CMS.
https://xibo.org.uk/manual-tempel/en/install_environment.html
