Hi there,
I am new to Xibo and i run into problem when i try to send content to my LED Wall display.
The LED wall has a resolution of 1536 x 576 (a 8:3 ratio) so we setup a layout resolution which is exactly 1536 x 576. We use a laptop on site to receive the content and send to the LED wall processor. As the processor could only process 16:9 / 4:3 content, what we usually do is to deformed the 8:3 image into 16:9 shape and send to the LED processor, the processor will handle the rest and make it on scale again on the LED display. However, when i sent out the layout, it was automatically scaled up but it was not stretch to full screen. The image is vertically centered and has a black bar on top and bottom. The wording and images are distorted after the LED processor re-scale it to 8:3. I can’t seems to find a way to deformed a 8:3 layout and distort it into a 16:9 /1080p output.
I figure out if I setup a normal 16:9 layout and manually distort everything i drag in (to make it proportionally narrower after calculation) the content could appear in a correct ratio in the wall. But that took a lot of time to calculate if i have a lot of widget / layers and the freeform tools in the layout doesn’t allow me to key in the exact pixel i want my widget to be.
Is there a way to force/distort a 8:3 layout into a 1080p so i could design everything on scale in layout to save time?
Thank you very much.
