I installed the Xibo_for_webOS_v2_R206.ipk with success on the tv, but when I launch the Xibo app it’s stuck on the loading screen.
The TV is :
modelName : 43UK6300PLB
sdkVersion : 4.3.0
firmwareVersion : 05.30.15
Thanks for help.
The TV is :
sdkVersion : 4.3.0
Thanks for help.
Hi jduval, welcome to the community!
The 43UK6300PLB is an LG smart TV, which is not supported with the Xibo for webOS player. Below is a link to our supported hardware list for webOS, which shows all of the models that are compatible with the Xibo player.
Xibo for webOS supported hardware list
Thanks for the answer Dan, ok so it only support LG Signage series. I thought it was all the WebOS TVs.
