Hi
Is rtsp streams in local video supported by the Linux Client player?
The roadmap for the client afaik doesn’t mention it here
If I add a local video with an rtsp command such as this
rtsp://login:password@192.168.1.1/defaultPrimary0?streamType=u
It produces an error relating to the @ symbol in the terminal windows visible in the background - the above being the usual way of passing login and password information in the rtsp command.
If I remove the login information so it’s just
rtsp://192.168.1.1/defaultPrimary0?streamType=u
once the layout downloads the client closes.
Any attempt to restart the client results in an immediate close without error message.
I have to reschedule a different layout and delete the .xlf files in the local library to regain control of the client.
I’ve mentioned this recovery procedure elsewhere in this forum - here
I’m using the latest cms 2.1.2 and I believe the latest linux player installed using snap and the player is using the linux display settings/profile in the cms.
Hopefully I’ve given enough information.
Jeremy
