I am new to PHP and I want to make an automatic login script for an IP camera (Foscam FI9831W).
How can I do this and in which folders do I have to save these files?
If I understand correctly, the script can sit on any web server - you may well chose to use the Xibo CMS web server to achieve that.
As for which folder - it depends how your web server is configured… the root Xibo folder should work, but i’d recommend at least putting it in a sub folder and if possible in a separate virtual directory.
It looks like the camera outputs a still image each time you request the web interface - so the solutions you are looking at have some automatic refresh built into them.
Have you tried just putting http://user:password@camera_ip_address/cgi-bin/jpg/image.cgi into an open natively browser module?
I’m afraid there isn’t much mileage in me trying to debug something that exists outside Xibo - I don’t have an IP camera to test with, which will make the process impossible. I don’t see why that script you’ve pasted wouldn’t work if you saved it as “camera.php” in the xibo folder and referenced it in a webpage module.
And by referencing you mean just putting http://user:password@camera_ip_address/cgi-bin/jpg/image.cgi into the Webpage module? Of course I need to change user, password and camera_ip_address.
Exactly so - the fact there are a lot of posts about this elsewhere indicates that this might not work (although they say it works in firefox - we use IE and Chrome though).
I’m no expert on that camera - but it looks to me like the feed is only available as a set of still images. You may need to consult with the camera manufacturer to find out if it allows streaming.
Via VLC I now have managed to get a live stream of the camera (although the stream stops after about 2 minutes), but do I have to use the Embedded module or Local Video?
If I have to use Embedded module, how do I need to set up the HTML, CSS and HEAD content to Embed?
The VLC plugin should be OK on Windows. There is no Xibo Player for Linux so you won’t be able to do that.
On an Android Player, all you would need to do is add a LocalVideo module media type and put rtsp://username:password@camera_ip_address:80/videoMain as the video address. You might want to consider that.
