I have been trying to do research about playing a UDP stream on xibo 1.6 ubuntu.
I have tried that:
- using a browser VLC-plugin but the there is a small window popped up.
- Using a shell command to call VLC directly, but the client called VLC played every one second.
I have been thinking that is there any solution that can do a UDP stream via xibo 1.6 like building a new module for python player to handle a UDP stream?
Is there any solution?
