I’ve tested a third party CMS which provided the ability to create multiple pages associated with the same layout, adding hotspots to navigate between them and display a web page (input form) on a region.
For some reason, the virtual keyboard was not executed while focusing in a form field and it turned out that the system did not support that… just a comment so this is considered in Xibo…
Whoops! We will make note of that although I must say that I can see why it would be difficult (with the virtual keyboard effectively gobbling up a whole lot of screen area)
Im also new in Xibo - my request for Interaction with System is a little different:
Screen should display slkdeshow (like usual Xibu Installation) - as soon there is a User Action (in our Case a Remote Controll) slideshow should stop and bring up a Menu (Picture Based) with availible Videos to playback - then User can select a Video - playback it …
Then after leaving Menu or after Timeout User Menu sholud hide and usual Slideshow should start again.
This Feature would be great …
As REmote Controller there are many options: IR wirth LIRC, Bluetooth Remote and so on …
I think that the remote control acts as a standard input (i.e. the application wouldn’t need to know the difference between touch and remote). Although in your case it would need to listen for “move” events rather than “press” events.
An interesting requirement for sure - we will take it in to account.
The Reason why i dont like Touch solution is simple that this should not be used by end User - only a Salesman should be able to take a Remote Controller and show Videos …
The other thing is that Big SCreens with Touch are very expensive and a usual Remote Controller will not cost a big amount …
Sorry, I wasn’t suggesting you use touch - I was explaining (for my own reference later) that they are effectively the same as far as the app is concerned.
We have several “Multi-Use” Kiosks. These Kiosks main purpose is for a company intranet. While the Kiosk is not being utilized, we use a screen saver for displaying a slide show. Would it be possible to make a Xibo client that functions as a screen saver?
I feel that this thread may be similar in purpose.
That is FANTASTIC!! Thank you, and sorry for being a newb! We tested Xibo about 5 years ago, went with a commercial solution. We are now replacing that solution with Xibo 1.7.9.
From my perspective (food & beverages industry), a finger swipe function to scroll and a touch function to view more details would be nice. In addition, a timeout function (e.g. 60 seconds idle, without touch events) that return to the original layout would be a plus. Honestly speaking, 1920*1080 still short for an extensive menu. Even more so if a user is close enough to touch the screen. Font size has to be at a minimum pixel size to be displayed clearly sharp. Other thoughts are shopping mall public information display (PID) such as directory of shops and services, etc.
I’m just adding my use case. I think it is already listed above, as it is a very simplistic workflow.
I have a generic layout that shows weekly announcements for a church service.
I want the kitchen staff to be able to touch a button (Touchscreen or mouse) and change the layout to show the live stream video.
We do not have a precise spec for it, beyond what is written in the first post on this topic (which is edited to keep it up to date with current state).
Hi Dan,
I developped “something” like a template creator in which one can define a region as “clickable (one-click, dpuble-click)”. On clicking this “button” a URL opens in fullscreen with the options to close or go back. Also the idle-time can be set in milliseconds. I am trying to cut out the code snippet to be implemented in Xibo. The code is written in PHP and JavaScript.
