Interactive Mode Only 10 Actions Showing
Docker Version 4.3.1
I’m having the same issue as With CMS Version 4 - Layout Actions are limited to only 10 actions per layout design?
Only 10 actions are showing when editing an interactive layout. I have a touch screen display where selecting a corporate sponsor sends a command to another display that shows a video about that sponsor. More than 10 actions are working, but it makes editing the actions when there are changes difficult, since only 10 actions show in the layout editor. In the screenshot all of the interactive zones have working actions.
Thanks in advance.
Thank you for posting, I have passed to the dev team to take a closer look.
Any updates will be posted here.
Hello Aaron, could you post which action you do to play a video in a different screen? Web hook, trigger code, shell command with API? I’m struggling to do the same thing in my Digital Signage project. If you can give me a couple of hints I will be grateful to you. Thank you, bye.
A bug has been identified and reported here: Interactivity: Action Card displays only 10 list · Issue #3768 · xibosignage/xibo · GitHub
