Hi to all
i’ve installed Xibo 1.8 on CentOS 7 with this instruction
The problem is that when I go to http://localhost/install/ I see a white page…
Any error … only a white page…
Someone can help me?
Hi to all
Are you using chrome? I’m not sure what @almond meant by
Avoid using Chrome on install, it has strange problem.
but perhaps that’s the issue?
Assuming that you did follow all other steps then I believe navigating to the cms address should start the installation.
Nope… I use Firewox…
I’ve followed all other step but installation didn’t start…
