I’m new to Docker, but I’ve installed it on our Ubuntu server and getting ready to upgrade to 1.8.1 form 1.7.9
However we are running multiple services (web pages etc.) so I gave the original Xibo install set to localhost/displays
The install notes suggest that Docker places 1.8 in localhost, how can I make sure it goes into the subfolder?
Still not 100% clear where I set the CMS. DO I set the CMS_SERVER_NAME to =my.server.example/displays in the config.env file?
Or do I unpack the Release Archive to /var/www/html/displays
You would need to run Docker on a custom port - say 8080 - and then setup your existing webserver listening at localhost to reverse proxy the /displays URL to localhost:8080
