Installed as HTTPS
Wondering if it’s possible to install xibo as https. can you please provide the info how to install would be much appreciate
Thank You
With Docker, you’d need a separate reverse proxy to do the SSL termination for you.
It’s covered in the guide here:
Without Docker, then it’s simply a case of configuring whatever webserver you’ve chosen to enable HTTPS connections. Xibo takes no part in that.
