Importing Layout Failed
Currently now i’m using Xibo CMS 1.7.4
when i’m trying Import Layout to another CMS with similar version,
Importing Layout Process was completed and reporting success
but when i lookup the design of the importing layout,
i found that dataset inside the importing layout doesnt import to my CMS.
so how i have to solve this issues ?
thank you
Datasets are not imported with the layout unfortunately.
You’d need to either recreate the dataset on another CMS, or import .csv file with it if you have it.
And then recreate the ticker/dataset view on your layout so it’s linked with the correct dataset.
Thank you for your response
if you said that dataset not include on Exported Layout,
It’s mean Export Import Layout not good for big dataset,
cause we have some dataset with many row,
and we showing the dataset at the first 10 second for row 1 till row 10
next we show some image and video
and next we showing the dataset for row 11 till row 20
and then show some image and video
we show all row at the data that almost 100 row data
so if dataset not include at Exported Layout,
that’s mean, i have to one by one configuration for viewing the dataset
it’s so wasting the time ?
do you have any tools or shortcuts , without doing all the configuration ?
thank you
any one can help ???
