Images disappearing from layouts and media list
When i create a new layout and schedule it, it works fine for a while then the image disappears and a broken image is shown? Any ideas why this happening?
Hi!
So we can help you further can you please confirm which widget is used to show those images : the image widget or the sub-playlist widget for example?
Can you please expand as well on what you mean by ’ broken image ’ ? is it a partial image or the resolution is incorrect or it shows the region in white for example?
Also please confirm :
  • your CMS version
  • the type of install : Docker or if custom your environment details
  • the type of player and player version that you use
Thank you!
Hi Neil,
Thanks for getting in touch.
The CMS version is: 1.7.9
I’m using Xampp - Apached and Mysql
The Player is on Windows 1.7.9
I’m very new to this.
As you can see from the image it is a little broken image logo that is shown where the image should be.
Cheers, Tev
Failed to load image: index.php?p=module&mod=image&q=Exec&method=GetResource&mediaid=1023
This is what comes up when i click on the images on the media list?
Any ideas?
