Now I need a webserver to host some ASP.net Websites. If I install IIS, Xibo can’t be reached longer over http://localhost/ because the default IIS Website is then located on localhost.
Is it possible to run both xibo and IIS or is there a possibility to use the webserver which is used and created by Xibo?
All I have to do is to change the “80” to 591 for example, save the file without .template and run the docker with “docker-compose -f cms_remote-mysql.yml up -d”? Is that right,because it doesen’t work.
No. You need to follow the instructions in the manual for running the CMS on a custom port. That very definintely doesn’t involve the remote-mysql.yml file
