After migration without skipping nignu error. The option to add screen does not work. It doesn’t work using the code, or manually putting the settings in the app. The error is "HTTP request failed, HTTP status: 500.
Thank you very much for your help
I’ts custom or docker installation?
Custom installation. On a CentOS Linux 7 and Php 7.0.33
Oh i see… Actually I don’t have much experience with Xibo on Linux, but try to use the PHP 7.2
Or Try PHP7.4 I had problems going from 2.3 to 3.x and solution was to go to PHP7.4
Now I have switched to Docker which is better! Even managed to export/import database from custom to docker!
