I’ve built a simple webpage that auto refreshes every 5 seconds using HTTP-EQUIV=“refresh” and I have noticed that this breaks playback of the region timeline. The 5 second refresh seems to reset the playback counter set in the timeline for this particular item and the region never moves on past the first item. If I remove the http-refresh things work as expected.
I realize i can avoid this by simply removing the HTTP refresh header and queuing web item several times in a short interval, but this causes the player to “blink” very briefly while the HTTP-refresh does not, and allows for a much smoother viewing experience.
I’m new to this product and I’m guessing that this is a glitch, but feel free to correct me if its working as intended!
I didn’t use HTTP-EQUIV=“refresh”, but as I understand it does refresh whole layout, what if you would set it to a bit longer than every 5s (perhaps to duration of your whole layout?)
Peter, My tests show a short flicker (fraction of second) between every ‘timeline step’ in a region, not just when the whole layout restarts.
It’s unfortunate that the HTTP header affects the region execution because the only thing I can think of to circumvent this is by using javascript/ajax instead.
