Hello Dan
I have appreciated for the attached URL. I am still a learning curve for a great tool and easy access for each module. This is a new (PowerPoint Configuration) to me as well.
Changed the subject (PowerPoint):
Based on PowerPoint configuration indicated by URL, only Office 2010 PowerPoint could be uploaded as Video Module of CMS. Any PowerPoint file made before Office 210 version cannot be uploaded as Video Module. Am I understanding it correct? If yes, how do I play old PowerPoint material with other image (second zone) in total layout in CMS installation?
“Note also that Xibo will not advance the slides in a Presentation, so you should record automatic slide timings by going to “Slide Show -> Rehearse Timings” and then saving the presentation._”
Should I record the Video based on above comment?
Thanks,
