HI,
May i know how to setup Xibo cms in my local system . i am getting error in command npm build .
Hello and welcome to the community!
Please do take a look at our CMS installation guides here: CMS Installation Guides
We would highly recommend that you use a Docker environment to make it easier to deploy a Xibo CMS by following our recommended configuration.
Thank you, But how can i do it without using docker,
i need to install in my local system.
You will need to follow the Custom / Manual installation guide here: https://xibo.org.uk/docs/setup/xibo-on-a-web-server
Please note: As Docker is our supported method of running Xibo it may not be possible for us to provide the assistance you need without opening a ‘paid support’ incident.
