i am a new user .i installed both server and client .Now i created a layout and saved ,how to send content with out sheldusing.
straight content sending .
You need to send your content via the Schedule.
You can just set it as the default layout but that then gives you nothing to fall back to if there’s a problem with the content you schedule.
Hi
I f you are free can u just brief how to send content
The guide in the Manual is a full walk through for content creation and scheduling so that would be the best place for you to start:
You can make a layout the ‘default’ for your client and it will always start with this content.
However the power comes from scheduling and it’s worth getting to grips with it.
