I hope the title explained my desired outcome well. I have 4 bullet points in a column in Excel, that when exported to a CSV and pulled in as a dataset, is simply displayed as 4 sentences with no bullets or spacing. How should one pull in a bullet list from a CSV in order to have information appear as a bullet list?
You will most likely want to edit your ticker appearance tab and add formatting there.
