Hi all,
I’m trying to create a layout to play a multicast stream like this src=“udp://@192.168.3.123:1234”
The stream is working fine in VLC player. I tried several embedded code but no one is working… Please find bellow what i’ve been tested.
Is there anybody who already have created a “multicast” widget ?
Cheers,
Philippe
On what device are you trying to achieve this?
If windows, please use Windows Media player, if it works in Media player, 99% it will work on Xibo Windows
If using Android, please read this
