I am using the Stocks module and I am looking for a way for the “items per page” option to have multiple items horizontally as opposed to vertically. I can make it show multiple stocks stacked vertically but not horizontally. Is this possible?
Welcome to Xibo Community Forum Michael:slight_smile:
This is possible using our options in the Layout designer to override the default template and use instead optional Stylesheet and eventually optional JavaScript. Providing that you’re using the latest version of our CMS : 2.0.4, you can see those options in the Layout Designer under the Templates
tab you will find both Optional Stylesheet
and Optional JavaScript
. First you need to go in Preset
and tick the box ’ override template ’ then you can go in Optional Stylesheet to change the appearance of the widget as you’d like. Good luck!
