How to fix Error log, always_populate_raw_post_data
Inside the folder “public.html / xibo /” there is an “error_log” file with several messages with this error:
PHP Deprecated: Automatically populating $ HTTP_RAW_POST_DATA is deprecated and will be removed in a future version.
To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php: // input stream instead.
in Unknown on line 0
My hosting is shared, and I could not locate the option:
to set to “-1”
My php is in version 5.6.
Xibo 1.8.9.
Xibo isn’t suitable for shared hosting.
You need to have proper control over the server and environment!
