How to debugging?
How to debugging xibo, think you ?
Could you provide more information about what you would like to debug?
If you are experiencing an issue with your Xibo setup, you are also welcome to post the issue, we would be happy to help you.
Excuse me,xibo Using native php?
You would need to set the CMS into Test Mode to view suppressed PHP errors.
You can do this by logging into your CMS, select Settings, click on the Troubleshooting tab and change the Server Mode to Test. Whilst in Test mode, you can change the Log Level to Debug. You will also need to set an Elevate Log Until date. Finally click save to confirm the changes.
