I need to change default logo for xibo player , because that logo are display when the client start up , the mall management will be take the penalty if we aren’t change that logo:
Changing the splash screen is supported by default within the player. (Well the windows player anyway. Hopefully someone else can confirm if this is also supported with the Android player.)
Yes, you can change the splash screen locally on the player (both Windows and Android).
Since here is the windows client in question, you’ll want to open Xibo Player Options, navigate to the advanced tab, there is Splash Screen field that will let you change it locally on your player.
