How much Xibo takes Bandwidth?
I have to know how much Xibo takes bandwidth. I want to install 10 players and I don’t know how many players I can install on my local network.
Sorry for my english … I’m french
Answer to your question is, that depends.
Depends on how much content will you be pushing to the players, how often it will change, will there be tickers etc with update intervals, if you will have logs or stats enabled, what log level etc
It’s impossible to answer your question without knowing any details about your project I’m afraid.
I don’t have so much media on my Layout. My project: I want 10 screens with only one layout. 5 texts zones. and persons can only modify the text or the font of the layout. And if they modify it’s 2 or 3 times by day…
I put the refresh layout all the 4 hours
If player will not need to download bigger files from CMS ie it will be mostly text, then they will not consume much bandwidth, it should not be an issue at all.
Ok Thank you Peter for your answer.
Have a nice day :slight_smile:
