Windows
Installing PHP extensions on Windows is easy and the php_fileinfo.dll extension should be bundled with the PHP installation (if it isn’t then it is likely the version of PHP you are installing is too low).
There are plenty of articles giving detailed steps for this if you search for php windows php_fileinfo.dll, however the basic process is:
- Find the PHP installation, look in the
extfolder and make sure the filephp_fileinfo.dllis present - In the PHP installation, look for the
php.inifile and open it with Notepad or similar text editor - Search for
php_fileinfo.dlland you may find a commented out section. If you do then uncomment it (by removing the leading ; character). If you don’t then add a line for it:
extension=php_fileinfo.dll
- Restart your Apache web server service
Ubuntu / Debian
fileinfo is installed and enabled by default
Synology DSM 5
Enable the fileinfo extension by the following route:
Control Panel > Web Service > PHP parameters > Select php extensions
