This works on our Windows display clients (1.8.2, as is the back end):
First, make sure the Optional Stylesheet for your ticker includes .hide { display: none; } so that you can hide items that don’t fit.
Next, in the Format tab, change the Number of Items to more than will fit on your screen.
Finally, in the Advanced tab, put this in the Optional JavaScript:
$(document).ready(function() {
var x = $('#content div.item');
var total = 0;
var maxheight = options.originalHeight;
var pMargin = 16; /* 1em */
x.each(function(i,item) {
var e = $(item);
var h = e.outerHeight();
total += h + pMargin;
if (total > maxheight + (pMargin / 2)) {
e.addClass('hide');
return;
I am pleased to have answered a question I raised.
