Grafana Dashboard - Xibo WebOS
I am trying to add my Grafana playlist to a Xibo CMS layout using the “Webpage” widget but the page does not load, it always displays a “Connection Refused” error. I’ve tried using the Embedded widget but the error is the same.
Does anyone know how I can solve this problem and be able to display the page?
Thank you.
Hi Asm19,
Welcome to the Xibo Community :slight_smile:
Do you have a Cloud CMS or are you self hosting the CMS?
I imagine you have checked that your Display is connected to network? If so can you please share the website URL that you are using with the Webpage Widget? If you prefer not to share it publicly. You can send it via private message.
Thank you.
Hi Nell,
I have my CMS internally.
I imagine you have checked that your Display is connected to network? Yes, of course.
For example: https://play.grafana-zabbix.org/d/000000011/grafana-zabbix-org?orgId=2
It is the same page that I want to place internally.
