Global Layout Duration Does Not Update
Version 4.3.0, Docker self hosted
Since upgrading to 4.3.0, we noticed the global layout duration at the top of the layout designer does not update correctly for image and text widgets…
Reproduce issue:
  1. Create a new Layout
  2. Drag an image onto the layout
  3. Select the image, and click the Advanced tab
  4. Check “Set a duration” and change the duration
  5. The duration will show correctly in the layers view, but the global layout duration at the top does not update.
The same also happens with the text widget. But other widgets like Webpage update the global duration correctly.
-Ben
Hi, thank you for posting.
We have identified a bug and have created the following issue: Layout duration not updating correctly with Global Element/Image · Issue #3725 · xibosignage/xibo · GitHub
Thank you.
