Can get help for below issue will running the xibo player.
While I am laughing the client getting exception as below:
Terminate called after throwing an instance of boost:: exception_detail::clone_impl cboost:: exception_detail::error_info injectors cboost:: property_tree::ptree_bad_path>>
I am trying to run xibo player on Linux Ubuntu 16.04 but facing the issue after clicking on launch client button.
Please let me know if I am missing something.
Thank you for your message. I have installed Ubuntu 16.04.6 and was able to install and launch the Xibo for Linux player.
I would recommend uninstalling the Player and making sure that Ubuntu is up to date before attempting to reinstall the Player. Can you also confirm the command you used to install the Player? For reference I used snap install xibo-player --channel=stable
Thank you for the information. I suspect the issue may relate to the fact you are using 1.8.9 CMS, which I don’t think has a Profile for Linux. I would recommend upgrading your CMS to 1.8.13 and then trying to connect your Linux Player again. To confirm, I was using 1.8.13 and 2.0.4 CMS when I tried Xibo for Linux on 16.04.
When I am using rsa public to get the data from cms unable to download the data from cms in xibo player. Can I get some idea how the cms is using this RSA key to identify the authorize user and gives access to download it’s data…
Many thanks
While installing xibo player on Ubuntu 16.04 and trying to run below command:
Sudo docker build -t xibo-linux .
Getting some error while this command runs
Pem_common.cpp
X509cert.h : Certificate was not declared in this scope .
Pem_read.cpp error.
Many thanks
