GeckoFx not displaying page correctly
I’m using the GeckoFX winforms control in a .Net app to display a Predix Platform app. Not all of the components in the page are rendering, and the Javascript redirects aren’t working. But everything loads fine in the latest version of Firefox.
Note that I’m using the binaries from https://www.nuget.org/packages/GeckoFX/ instead of initializing Xpcom using the Firefox dir. If I point Xpcom to my Firefox dir I get these errors:
Gecko.Xpcom.DirectoryServiceProvider.GetFile: not implemented: permissionDBPDir A first chance exception of type ‘System.Runtime.InteropServices.COMException’ occurred in Geckofx-Core.dll Error: 6/12/2017 10:10:09 AMMainUnhandled Exception: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)) Audit: 6/12/2017 10:10:09 AMMainStack Trace: at Gecko.nsIServiceManager.GetServiceByContractID(String aContractID, Guid& aIID) at Gecko.Xpcom.GetService[TInterfaceType](String contractID) in D:\temp\ddfb20c\Geckofx-Core\Xpcom.cs:line 745 at Gecko.DefaultPromptFactory.Init() in D:\temp\ddfb20c\Geckofx-Core\PromptService.cs:line 79 at Gecko.PromptFactoryFactory.Init() in D:\temp\ddfb20c\Geckofx-Core\PromptService.cs:line 60 at Gecko.Xpcom.Initialize(String binDirectory) in D:\temp\ddfb20c\Geckofx-Core\Xpcom.cs:line 381 at XiboClient.MainForm.InitializeXibo() in c:\Users\220023166\Documents\Visual Studio 2010\Projects\xibo-dotnetclient-1.8.1\MainForm.cs:line 165 at XiboClient.MainForm…ctor() in c:\Users\220023166\Documents\Visual Studio 2010\Projects\xibo-dotnetclient-1.8.1\MainForm.cs:line 156
at XiboClient.Program.RunClient() in c:\Users\220023166\Documents\Visual Studio 2010\Projects\xibo-dotnetclient-1.8.1\Program.cs:line 136 at XiboClient.Program.Main(String[] args) in c:\Users\220023166\Documents\Visual Studio 2010\Projects\xibo-dotnetclient-1.8.1\Program.cs:line 118
Is there a security setting or something I might be missing in order to get this to work? Or is there a way I can view the webpage console through GeckoFX? I’ve inspected the page with Fiddler and it looks like all of the elements are loading correctly.
Can you provide more information about your setup and confirm how you wish to use GeckoFx with Xibo?
