I just started with xibo 1.7.3. I set up my first Windows Client and tried to Play some short 15sec Videos Fullscreen in a row. I noticed that there is always a 1sec gap (black Screen) between the videos, which is not very pretty.
Is there any Chance to get rid of this gap to let the videos Play back to back?
I’m on Windows 7 with i5 8GB Ram and SSD as media drive.
Robert,
I haven’t been using Xibo for too long, but I have experience what you are describing. I don’t think you can actually remove/ reduce the transition time. This time is more or less what it takes for a workstation to end one video and move to the next. I have found that changing the background color of the layout can definitely make the transitions look better. For example, in my environment a lot of what we display has white backgrounds so changing the background color of the layout from the default black to white really made a lot of difference. Also, do you have your videos in different layouts or the same? The transition might be longer if the videos are in different layouts than if they were in the same. Just a thought.
Kevin
thanks for your thoughts! Did that but I still have a short black flash between the videos. That really doesn’t look nice. So the only option is to fade all videos from and to black.
Any chance that one of the programmers could fix this in a future release? Gapless playback is an important feature to every POS-system. If I play the videos in the media player it is possible to play them without any gap so it should be possible in Xibo too. Or do I miss anything here? Is there something that I can tweak to make this work?
You haven’t missed anything - what you are experiencing is the raw time it takes the PC to remove one video and replace it with another one.
We have this as an improvement point for our new player development, where we will try to render the second video off screen so that it is ready to rock when the current one ends.
Hi, place a full screen image in the background of the template. I use my logo. During the gap, the logo appear (depend by the gap time). Waiting a xibo’s transient solution (for me) my solution solve partially the problem. Ciao
Hmm dunno if i was clear. Logo picture is set as background of the layout. i use this method from 1.3.2 and now also testing 1.7.3. I think is a natural situation of preload gap. All video or content insert in a vlc playlist (for example) have this problem. Also suppose that a preload and a transition method embedded in xibo player, raise cpu and video calculation (and low budget players (atom or android) maybe don’t support. BTW try use a low res image for background. Ciao
Sorry, we don’t have any dates for 1.8 release at present. We will likely make a CMS only release first, as a new player is a large development and will take longer.
Just getting started with Xibo and I’m loving the features available but the small black screen gap in between repeating my very short video is driving me nuts. It looks very ugly when this video will be on repeat all day and night. Will there be an update to this relatively soon?
Or is there a seamless repeat option for videos that I have not been exposed to? Any update or information would be greatly appreciated.
