Fresh installation on localhost fails : SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column 'title' at row 38
I am trying to install fresh Xibo but facing some problem. The details of my environment as follow :
  • Xibo 2.0.1
  • Wamp 3.1.7 32bit
  • PHP 7.1.26
  • MySql 5.7.24
  • PHP Myadmin 4.8.4
Error : SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column ‘title’ at row 38
Can anyone help me to solve this issue.
We’re aware of this issue on manual installations with MySQL 5.7 strict mode, it will be resolved in 2.0.2 release - there were several small changes to the installation migration in 2.0.2.
We’re currently aiming to release 2.0.2 next week.
Apologies for the inconvenience.
You can get it to run by turning strict mode off for MySQL 5.7.
I would not suggest using Xibo v2.0.1 in a production environment only use for testing.
I would also suggest you check out my recent post on issues I had with 2.x.x. I included 2 links that will help solve your issue.
