I’m experiencing the same thing on a number of displays that are at a different location/timezone from the CMS. Timezone, time, location, etc. are all set properly.
If you do use international date format - it should be fine on 1.7.6
You can also try it with default date format ie:
Y-m-d H:i
and ‘show international dates’ unchecked
This is still happening to me, and I apologize for posting and not being available to comment :). Anyway, I’m running the latest Windows client (1.7.6), and the latest CMS (1.7.6). I’m also not using the international date/time format.
I was using one layout for all the displays at different locations, and setting the location on the displays themselves. This works great in my office (Greenville, WI), but in others, specifically our Mansfield, OH location, the forecast.io plug-in shows the day prior.
Today I copied the layout and changed the location manually for Mansfield and scheduled the layout… with the same experience. I have validated that date/time/timezone are all correct on the Windows computer the client is running on. I’m not sure what else I can do… is there any debugging info that may be helpful?
