First of all thank you for a great cms.
I have a problem with the Flip clock. If i add a region and chooose the flip clock, the region size adjusts to the clock size and thats all just fine. However, when I disable the seconds in the flip clock, the region stays the same size (or width) so that there is an empty space where the seconds used to be. If I try to get rid of that empty space to the right of the “minutes” by decreasing the region width, the clock just gets smaller and the empty “seconds-space” is still there. This makes it impossible to have a flip clock (with only hours and minutes) in the upper right corner of a display. The clock needs to be aligned to the right, so to speak.
Have I missed anything? Using local cms on ubuntu 16.04 and windows client/player.
EDIT: Using cms 1.8.5 and windows player 1.8.3.
